Are you sure you need to remove your shifter? You may very well need to but Ive ran new transducer cables in two different model BCBs and never had an issue with the shifter. Im not saying this will work in your situation but what has worked for me in the past was to feed a long piece of electrical wire used for wiring a home – think it is called coax – from the rear vent to dash/ shifter area and then pull the new transducer cable through attached to the end of the electric wire.Jason Ferbrache – Edmond, OK 1995 Basscat Eyra
