I changed the plugs on my XR-6 today and noticed a small diameter coiled up hose that was connected just below the bottom spark plug on the right side of the engine. It was plugged off on other end and about 2ft long. Is this already set up for a water pressure gauge? Will this make it fairly simple to add the gauge? Thanks for your help ElwoodElwood…..Bass Cat Proud
It sounds about right. This is a pic from the lower right hand side of my xr6.That should be better.Last edited by ChuckFishes on February 28th, 2008, 8:22 pm, edited 1 time in total.
THATS IT!!!!!!!!!!!!!!!!!!!!!!!!!!! How hard is it to run from there and what else do I need to do it. Can Bass Cat still match up the guages and the red aluminium ring around the guages? ElwoodElwood…..Bass Cat Proud
Elwood, you can get the gauge from any Mercury dealership and we have the rings in stock always. The colors may vary a tad, though they will be close. BCB
