Picked up my new-to-me 2009 Sabre and I would like to correct one issue I have. The center roller, the one that keep the keel/pad off the torsion axle, is touching the pad. It is evident from the marks ahead of the roller that the roller is contacted when loading the boat. It appear that it is only contacting the roller at the ends of the roller. My thoughts are to replace the V-shaped keel roller with a straight roller (see photo) cut to fit in the same roller tabs on the trailer. Since the boat appears to be resting fully on the bunks, my thinking is that the straight roller will assist with loading and then clear the keel of the boat when full on the trailer. The new Stolz roller is approximately the same diameter as the center of the old V-shaped roller.Note: the bunks are sound, securely attached and appear to be the original bunks. Feedback from BCB would be greatly appreciated. Otherwise, this is a great boat.
