Still figuring out my livewells…The portside well is the drain for both wells….that drain has the push pull cable valve with a pump attached to it (for recirculating on the portside well?).So I first noticed the cable wasnt tight in the clampy on the valve. But dumped 5 gallons of water in the portside well (other side is plugged off) and the water drains past the valve, no matter where I move the lever to.What a $#+!$ its gonna be to get that out from under two other hoses….but anyways, what do I need?Flowrite repair kit?https://flow-rite.com/products/marine/valves/ma-060or a new valve? Which valve, V2 – “Empty / Auto” Valve?Thanks
