97 Jaguar and my live well is not filling up. I can fill it with a bucket and the recirc works and I can empty but not fill. It must be the fuse or pump but I cant find a fuse box. Is there even a fuse box in the thing? I dont want to take the pump off if I dont have to. Any help would be appreciated… Thanks, Rick
You have a BP 101 dash and there is no fuse. It could be the pump and does it show “Fault” in between the auto and man lettering on the dash? Have you checked for power at the pump? Have you reversed the wires from the bilge or recirc to verify that the pump or wire is functioning? Lots of things to look at! Plus you can read the FAQ section or the BP 101 manual in the drop down menu on the home page At http://www.BassCat.com. We will help more if you start narrowing things down.
Yes, for years everyone first thinks it is dash, and usually it is something else. We have even seen people spend hours putting in a switch panel when a bilge pump or aerator was out. The fail to look first at the component.
