DO NOT DRIVE THAT BOAT! You have a seal out probably, or a hose issue. In 1991 BCB did not install hydraulic steering, so this is an after market modification. The steering must be researched, and it will leak when you turn it to full lock and rotate the steering wheel. You will easily find the source. Hooking to the trolling batteries will require going direct to the rear with new wiring. BCB
