Home › Forums › Bass Cat Boats › loose fender
2012 tandem trailer with loose fender. What type of adhesive should I use to stick it back on the steel plate?
I had the same problem with mine. I would call Pete in parts. He will have the adhesive and will give you instructions as well.
I seem to recall a thread on re-gluing the fender to bracket a couple months back. Try a search on here, might find the info you are looking for.
This was the post about mine…http://basscatowners.yuku…-Fender-Vibration?page=1
Call parts. They have the right stuff and instructions to do this!
I believe the factory uses a windshield urethane adhesive called “Euroflex”
Plain old contact cement has held in for going on 5 years for me.Treat everyday like it might be the last
Urethane windshield adhesive.
Thanks for all your help! Brad
