Not knowing the age of your engine and just going history could be as simple as a cdm(coil) are and injector. Most important take it to a mercury tech.
I knew before I opened this post you had a mercury. My money is on a bad coil which these motors are famous for. Been there done that twice. They now have new coils and the problem should be resolved once installed but they lost any future business with me. Going back to yammies soon as I can. Nothing worst then being standed away from the ramp with a bad coil on a new boat with 10 hours on it.
have you took a volt meter to check your battery. then check your master switch it could be broke. Start at the power source (battery) then go from there.
Sounds like something major may have happened and knocked out either the engine fuse or fusible link. Also the Matt and breaker has a reset on the end of many breakers. Which would indicate something happened if it is popped.
Not sure what model you have. But there is a main buss breaker. If equiped that could be the issue as well. I believe its black with yellow writing and a yellow reset switch.
I have lost power to everything. To big motor, touchpad and graphs. I understand there is no fuse link anywhere. What should I check first?Thanks, Brian
