Im running a 24p bravo xs. As basspack mentioned, weight was my issue with the 24p fury. solo was fine. as soon as I added a partner and extra equipment, holeshot was terrible. Went to a 23p tempest, but again was along same line as the fury prop, little better on holeshot. I have a 24p bravo xs now and happier with it. still adjusting how many holes I should have open on it since I have 8 holes to work with. Im running the merc 150 four stroke, so tish less power than the two stroke will give you… Im running a little over 1 mph per every 100 rpm with it. That said, solo was 58.4mph (5,700 rpm). duo Ive had around 50 mph, but havent pushed for top speed yet with duo. I also have a fortrex and helix 12 up front along with 31 batteries. Im also a bigger guy at 290lbs, so again, Im not running as light as some are.Jared
