A deep-cycle battery is a lead-acid battery designed to be regularly deeply discharged using most of its capacity. In contrast, starter batteries (e.g. most automotive batteries) are designed to deliver short, high-current bursts for cranking the engine, thus frequently discharging only a small part of their capacity. While a deep-cycle battery can be used as a starting battery, the lower “cranking amps” imply that an oversized battery may be required.A deep-cycle battery is designed to discharge between 50% and 80% of its capacity, depending on the manufacturer and the construction of the battery. Although these batteries can be cycled down to a 20% charge, the best lifespan vs cost method is to keep the average cycle at about 50% discharge.[1] There is a direct correlation between the depth of discharge of the battery, and the number of charge and discharge cycles it can perform.[2]The structural difference between deep cycle batteries and cranking batteries is in the lead battery plates. Deep cycle battery plates have thicker active plates, with higher-density active paste material and thicker separators. Alloys used for the plates in a deep cycle battery may contain more antimony than starting batteries.[3] The thicker battery plates resist corrosion through extended charge and discharge cycles.Jim EbarbMany, LA (Toledo Bend Lake)2004 Cougar/ 225 OptimaxHumminbird Helix 12 Chirp SI on BalzOut Mount at bowLowrance HDS 7 at bowHumminbird Helix 12 Mega SI on Ram Mount at ConsoleLowrance HDS 8 in dash at console
