Has anyone replaced the upper motor mounts in a Mercury Outboard I have a few questions. I have a 98 200 EFI that has a bad from rear of engine right hand upper motor mount. ( I will replace both)I have and have read the service manual on replacement of them it involves removing the powerhead. The service manual doesn’t really defined how to just replace the engine mounts, it describes how to remove the powerhead and disassemble the powerhead and reassemble and install. The next chapter describes how to disassemble the mid-section and part of that is the motor mounts. What I’m looking for is: Is there any trick of the trade ie Time Savers in doing the job. The manual gives the information to completely remove the powerhead to include all electrical cables water lines, shift and throttle cables. Does all this really need to be done or can you leave most hooked up raise the powerhead enough to sneak in the new mount s and then reinstall. What if any tricks of the trade can be applied to just doing the Mounts
