Folks, Ive been noticing that my batteries are giving out earlier than usual. Im running 2 AC Delcos that are 9 months old and have the Cul-M-Rite 3 bank charger. Im not sure if I have a charger issue, battery issue or both. . I wonder about the charger because the output changed. Heres what I had last night. Charger connected and on Switched the leads and turned back on. Battery 1 13.35 volts Battery 1 13.06 volts Battery 2 12.75 volts Battery 2 13.14 Charger turned off right after lights turned green Battery 1 12.96 volts Battery 2 12.75 volts 24 hours later Battery 1 12.73 volts Battery 2 12.41 Volts TOne battery had a shelf life of 5 months and the other 6 months when I put them in the boat. So back to the original question. Bad batteries, bad charger or both. Im leaning toward bad battery. Thanks
