Leave it connected directly to the crank battery. Running extra electronics through the master switch and adding extra load to the boats harness is not a good idea. If you are concerned about parasitic drain, simply install a battery disconnect switch. I use BEP 701s for battery cut offs in my boat, and their installation is easy. Hopefully you have a quality cranking battery to begin with.
