This am when I turned the key (2000 opti 225 on a cougar) the oil light and buzzer came on and stayed on, the engine was still in the trailering position (for about 2 weeks). Pulled the cowl and the oil was within 3/4″ of the top of the reservoir about even with what appears to be an overflow, the boat tank was at 3/4 full. Turned the ignition off lowered the motor turned it back on, all was normal. Trimmed up again and the same thing happened. Put it in the water trimed down started and ran fine the rest of the day. The reason I ask is I never noticed this behavior before and if it is not normal I want to get a handle on the problem before something dumb happens. thanks irv
