Mounted MK 101 Maxxum Pro on 08 Puma. The front outside bolt at 3.5 “on the mount was not long enough for aluminum plate ,washer and mounting isolator to keep mount off deck to get a full nylon lock nut. Used just a regular 4″ machine screw for now. Is there anywhere I can find 1/4-20 x 4″ SS machine screws or would a 11/2” SS fender washer on both of the front bolts work instead of the aluminum plate. Thanx in advance, TomLast edited by tschooler1956 on February 21st, 2009, 2:17 am, edited 1 time in total.
