I have a 2003 P3.Before you put any tackle in the boat you will be real close to 3500 pounds.Hull weight is listed as 1490 for the Single Console and 1520 for the Dual. Tandem trailer is roughly 1000 pounds, 200 Opti is 500 pounds , 3 batteries approx 150 +, one tank ( 26 ) gallons 160, Trolling motor 75. That is 3400 pounds empty. Add in oil, spare prop, tools, graphs, then fill up the storage with tackle and Youll be pushing 4000 pounds.I also had a 1999 Pantera 3 and towed it with the same vehicle. The 4.0 will tow fine, just be sure the trailer brakes are up to par. Unless you live in a really hilly region you should have no problems as long as the braking systems are good or you want to win all the races on the interstates.
