Also you may end up with a gap between the two plates, dont worry they will tighten up once you put the powerpole on and torque them down such as in the pic below. I also recommend that once they are installed to check the torque on all mounting bolts after ypur first outing, especially the ones that hold the pole to the adapter plate. Check them often and especially after a bumpy day on the water.
