The pro-guide tournament batteries are phenomenal batteries, but theyre thirsty. Have you been keeping the fluid topped off and charged? Distilled water only? If you dont have a power source for charging where you store the boat – might want to remedy. The batteries need to be charged immediately when you store the boat, and should be left on a maintainer until you take it out again. If left discharged for extended times – youll significantly lose battery life and capacity.It would be a good idea to pull the starting battery and take it in for load testing and check specific gravity on all cells. If youve let them get low on water – might be a good idea to take them all. Once youve had a complete battery test – then, you can have the problem chased till its found…..Last edited by jstew on September 19th, 2014, 6:50 pm, edited 1 time in total.
