Danny,Just went to the garage to get you the numbers. The mounting bracket is M26SB. Its mounted in between the motor and the Detwiller jack plate. I went with the Starboard (SB) side because the hydraulic lines were easier to run through the existing hole in the back. I guess the anchor light is on that side as well so it gives the back-seater only one side to worry about.Ground to top of the pole is just under 84″. It does not clear the garage door. I use the wireless remote which was included to lower the pole back it in, then raise it back up.When I bought mine I called Rich at Hydrilla Gear and told him what boat I had and what jack plate and he told me what I needed. No noticeable change in hole shot with a 250 pro xs/26 Fury.
