There are two power feeds to the A10, one from the battery for the bulge pumps and horn/security/compartments lights, one through the master power switch for everything else. Check that you have power to the panel through both, if you do, thoroughly check the ground block mounted on the transom for loose or broken wires. And crimped connections that are not tight.
