That sounds normal. Light chop provides the fastest speeds. In slick water, the water sort of “sticks” to the hull with no wavelets to break the surface tension between the water and the hull. Prop slip cant be too bad at the speeds you are running, and early-morning running is always a bit slower with glass-like water conditions…2008 Pantera Classic2014 Mercury Pro XS 200
