Home › Forums › Bass Cat Boats › Psi 200 pro xs on a 2013 P2
Does anyone know how much psi should the gage be reading at 5k rpm??? I am getting around 22psi seems a bit much to me???
The newer gear cases with the front pickups run much higher pressures.
Ok so this is normal?? I shouldnt be worried about “to much” psi?
Nope, that engine cools on flow as much as retention and you need it to flow to the thermostats that regulate the flow.
