Just curious as to which pump is needed to replace the freshwater in pump on a 00 PIII. The little yellow nipple to the housing has broken off. Also not to sure how that thing connects to the transom. Dont want to damage anything else in the process of trying to replace it.
BCB Parts / Service can help you, give em a call! Ive had several Mayfair pump nipples let loose on me over the years. Their newer models have improved and are reinforced better in those areas so common to break in the past.
