Home › Forums › Bass Cat Boats › Question about winterizing my 175 Merc EFI
I keep my Basscat [w 175 Merc EFI] out of the water on a lift on Lake Hamilton…I would appreciate advise on what I need to do to winterize it…Thanks
If you have checked your gear lube and your engine is trimmed down to drain, then you should be fine in the middle Arkansas area. BCB
If leaving your boat on a lift for the winter, make sure your bilge is dry. You dont want a couple of inches of water in there to freeze and crack a transducer. The same applys to your livewell. Make sure it drains fully.
Thanks, I appreciate it.
