I got caught in a rain storm last night, and when I went to dry out the boxes the one that holds my oil tank had about two inches of water in it. So my question is, there is no drain hole, should there be .
I have the same issue, just not anywhere near a dealer, could some one post a pic of exactly where the drain should b??Water in mine is mostly from the cup holderThanksGene
flybyy1 wrote:I have the same issue, just not anywhere near a dealer, could some one post a pic of exactly where the drain should b??Water in mine is mostly from the cup holderThanksGeneNFCMF
I just took some pictures from my oil compartment on my 2016 Caracal. This is factory drilled. You can see the drilled hole. However if you have the rear tanks I would not drill it there. The tank is litterally just on the other side of the compartment wall. I would locate it in the center or the other corner. Hope this helps.Gary
