I ordered the new volt gauge to install on my Jaguar. It appears to need a 1 1/8 inch hole. What type of bit or hole saw does BassCat use to make this hole? I am thinking a forstner bit would be the best choice. Any help or advise would be greatly appreciated.RK
Ive used a hole saw several times with fiberglass gel coat. I always ease into the glass in reverse untill the glass is scored. Even after the glass is scored and running in forward go easssy. This will prevent chipping around the hole. Call richard at bcb. They drill holes regularly. He may have a suggestion as well!
Finally got around to installing the volt gauge on my Jaguar. The forstner bit drilled a perfect hole. No damage to the gel around the hole at all.RKLast edited by RKeeling on November 19th, 2017, 9:42 pm, edited 1 time in total.
