BCB, All, I plan to mount a Stealth1 “on the run” charger on the inside transom…..what is the length of screw I can use without putting a hole thru the boat, can I even do this?!?!?!? Thanks, BAM
Understand you dont recommend the unit, thanks, but I am going to use one, can you please let me know if screw mounting is possible inside the battery compartment on the transom? Thanks, BAM
