3beagle78 wrote:My recirculating pump will not stop running. I replaced the pump after about a year of it not working as soon as I plugged the new one and it started running. It does not matter if it is in manual, 5 min or 3 min it will not shut off. Anyone have an idea what it might be.ThanksI dont want to insult you but are you sure that its the recirculating pump? Check all of your other switches to make sure they arent “on”. Its easy to confuse these pumps and you could be looking at the “fill” pump and your switch is on. Hey, it could happen……….Ive seen someone else do that once. Or maybe you replaced the pump and wiring too? Could be that you dont have it wired correctly. I would look for something obvious that you might be overlooking.Everyone should believe in something. I believe Ill just go fishing!
