I have a 2018 Caracal w/ removable dual console. Is there a way to remove the 5 bolts when I take the console out. Doesn’t seem safe having 5 bolts sticking out like that.
It doesnt sound like you have the removable console setup. If you do, you just tap the threaded portion of the bolt on the end lightly with something soft, like a chunk of wood and it will tilt up and then you can slide it out of the slot. Here’s a video: https://youtu.be/__VTuzutnHI
Awesome! It worked perfectly. I had 3 not 5 bolts. I asked when I bought it. Can’t believe the salesman told me there was no way to remove those bolts. I knew that was too stupid for Bass Cat to design it where you couldn’t. Thanks so much!
