Hi, could you please tell me what the replacement is for the Quicksilver 3000 throttle quadrant? I have a 97 PII with a Mercury 200 EFI. Straight up on the throttle is now reverse. I needed to change the impeller anyways so I dropped the lower unit today and with the spline shaft was able to shift to all 3 positions and prop movement was normal. Nothing major ion magnetic plug soooooo I am assuming the quadrant and/or cables are bad . Figured I would change both while it is torn apart. What cables are the replacements also please? Thank yall.2015 Caracal
Not sure if its still visible, but they usually have the length on the cable. Also with the stretching of the cables over time, you may just need to adjust the cable position at the motor for correct shifting.
Probable cable failure . — Readily available through Pro Marine at a reasonable price . — Length is either 9 or 10 feet depending on routing . — Hope this helps . — Hoss
