Running electronics off a trolling motor battery can present two problems. Firstly, uneven draw will run down one battery prematurely. Secondly, the likelihood of graph interference is increased. Although you are already running your poles off your deep cycle batteries, it always recommended to run all accessories off the crank battery as this is the factory set up.
If you have a Pro XS, that Duracell is not a sufficient battery. With only 800 ccas, that is what a Merc needs minimum just for cranking. There is no allowance for accessories, so ccas should be up at least 975. Don Weed, the Mercury specialist on BBC classifies that battery as unsuitable in a bass application. A 31 Northstar/Batteries Plus X2 or a 31 Odyssey would be a much better choice with far superior specs. Both of these batteries require a high quality AGM charger. Another alternative would be to add a small deep cycle house battery just to run your poles and electronics.
