Guys,I already have the antenna mounted in the back.I tried fishing some wire like house wire ,it`s all I have so far.Do you guys usally use that contractor wire that comes on a spool looks like garage door wire (fish wire,not sure what it`s called)?Also do you have any tricks,I`m not sure if the wire corridor runs under the top cap or does it just run along the bottom,more open I guess.I pulled out the shift lever panel as far as I dare to plus it only comes out about half an inch ,so I just screwed it back on,I don`t want to open up something I`m not familar with.It`s on a 08 p2.Thank you guys,Greg in Wisc.
