I have a 99 Sabre that occasionally will get some standing water in the rod lockers. Is it possible to drill a small hole somewhere in the rod locker to let water drain down to the bilge? If so, where would you recommend drilling this hole?
There is a procedure for finding water leaks in the FAQ section of this forum. I definitly would NOT drill no holes. Contact Bcb and talk to Richard he probably can make some suggestions2013 PANTERA 2MERCURY 200 PRO XSMINNKOTA 80LB FORTREX25 fury
Thanks for the link. I wonder what the issue is with drain holes. guessing it would drain somewhere you wouldnt want it?This only happens to me in big water when the nose goes under the water.
bwp777 wrote:it happens to me on my 09 puma in heavy rain. if the nose goes under on my boat then ill be swimming to shore. forget that Thanks for the good laugh bwp. Same here!
bwp777 wrote:it happens to me on my 09 puma in heavy rain. if the nose goes under on my boat then ill be swimming to shore. forget thatI am with You!!Dan
