Home › Forums › Bass Cat Boats › Solo performance.
Alright guys I have a question! Loving my 2013 P2, but Im still learning the drive and performance characteristics of this boat. Heres my issue: With the boat fully loaded, tournament partner included, Im able to hit around 70-71, which I am certainly very pleased with. I have learned to control the boat and avoid chine near top end, and I feel like Im getting the most I can out of the boat with my current driving ability. The problem comes when I drop my partner off at the dock and head out for a day by myself, which happens a decent amount of the time. I am only able to achieve around 67-68 before I just feel out of control. Obviously seat time will be the best remedy, I just wanted to hear some specific suggestions. My tackle is mainly located in my forward most box, but I really dont carry a ton. Ive ridden both with full gas and with not much, and have problems in both situations. Ive heard that when alone, I should fill my live wells to compensate for the weight distribution, but that didnt seem to help either. Im turning a 25 tempest around 54-5500 RPMs. Motor is a Mercury Pro XS 200. I have dual 10 blades, but have driven the boat both with and without them, and they havent seemed to make a big difference in drive. Anyways, just thought I would throw this out there and get some tips! Thanks!
Not sure if this is your first cat or not.I ran a p2 a few years ago and they will run well.My first thought would be too much trim and you are pushing with the ransom.The hull you have really will get up and run pretty flat from my experience.I would suggest getting up on pad and getting up to the speeds your comfortable with get your rpms up and try bumping down the trim a small amount at a time you will get to know the feel and eventually feel the transom lift.When you realize what your feeling you will be able to do this single or with a partner.That is a pad o air packed under the boat which will gain your speed.my assumption is that you are referencing similar trim positions and you are over trimmed when alone.All bcb hulls loose speed and burn more fuel in this situation.and yes seat time will help.where do you live?
Trim in small increments and think about less trim than you feel you need.
Balance, balance, balance and balance. Go to BBC website and read about this issue. There are excellent articles regarding balance of weight in regards to performance. Here is just one thing I do in my boat. passenger side, port side I will fill that tank to a certain degree to compensate for not having a co-angler in the boat. If ya spend some time with weight distribution you can over come a lot of driving, chine issues. Hope it helps. Prop selection will play a role also.
Your over trimming. That hull requires little trim and with a light load it is magnified if you over trim.
Youre over trimming as stated above and you need to learn how to drive. Once you getting the driving part down you can drive under any weight condition whether balanced or not. A Trophy prop can also help you learn to drive as there is much more forgiveness in steering mistakes and there is another blade in the water to help you balance the hull on the pad. You can read everything that you ever wanted to read about chine walk, but unless you put the seat time in youll likely never get there.
Thanks guys I really appreciate it! I definitely agree with everyone that Im over trimming and just need more time and experience. Im down in Thomasville, GA. Im heading out alone again to Lake Talquin this Friday and Saturday, so Ill certainly keep my mind on less trim. There arent many guys down here with cats, so I dont have many to ask in person. Love this board. I havent considered the trophy yet, but I have been thinking about a fury. Any thoughts?
Requires less trim than a Tempest, less engine height than any of the others. Easier to drive than a Tempest, but harder to drive than a Trophy.
