Having occasional issues with not being able to trim up my motor (2005 Mercury 225 3.0 EFI). Problem most often happens after the engine has been sitting a while. Nearly every time I try to raise the motor the 1st time to remove the transom saver it will not go up. I can hear the motor turning but nothing happens. Always goes down though. After I bump it down, then try back up 2-3 times it goes up. The rest of the day it seems to work ok. Replaced the motor in 2014. Had the o rings changed on the hydraulics last month (leaking). Was hoping it was low fluid or air, but the problem persists. Doesnt matter which switch I try; cowl, throttle, or blinkers. Not sure if they all go to a common solenoid. Any comments would be appreciated.Sent from my SAMSUNG-SM-G930A using Tapatalk
