If no multimeter, use a knife blade/small screwdriver and spread the pins in the light socket, then try new light or bow light. You may have to force the light down a bit,,,,,, If no power check all connections at the terminal block in the rear, on the transom so all are tight with no corrosion . After all that you are down to drilling out rivets and removing the light base to check connections there.
