Check all your latches to make sure they are snugged up, you should not be able to spin them at all. I had a few loose ones. Pour water into your front cup holder at the bow, and look to see if water enters your center rod locker, some times the drain tube comes off and or becomes misrouted. And keep your bilge dry, on take offs its a good practice to click the bilge on for a second or two, and leave it on auto. The water can rock back and forth in the hull and splash to the bow, the rod locker is not fully sealed at the nose. Even with being very careful letting the boat down, I still get some water entry over the back though my cable harnesses and power pole grommits, it adds up quick.
