I have a 98 Panterra 2 that I need to replace the super dash in. It seems that I am out of luck with basscat??? Has anyone found other solutions to replacing one of these?
The retro units are able to be installed, though the A10 assemblies are out of stock. Most BP dashes have ground issues and not dash problems. Be sure you check your connections.
Thanks for the response. Will check ground issues again. Any update on when the conversion kit will be available. Ive been trying for 3 months to get one.
Ground seems fine. Some items work on the panel while others dont. What are my options? Please Help, going through a lot of trouble and expense to redo this boat. Would like to be able to have a working dash so that I can actually use it.
Plug in the hot wires and grounds and check the actual dash itself. The fault codes will come on if there is no current flow, like leaving the bow or stern light out.
