Took the boat to the gas station to fuel it up. I noticed the trailer bumping harder than normal wen stoppoed and taking a off. The black cap that goes on the toogue to acess the fluid plug has fallen out somewhere. Question is: Will this be a problem till i can get a replacement? . Any help is appreciated
Depending on where youre at call Martys marine, Osage Beach,Mo. Mid-West Marine Harrisonville, Mo. or Bull Shoals boat dock, Im sure they can help! Numbers are listed on the dealers section!
The black plastic cover is only for looks.. It really doesnt do anything functional for the brakes. If your getting a “bump” stopping or taking off you probably have low fluid..
Thanks all. I did fill the fluid up and re installed the plastic cap that says tow, back up and something else on it. It was low and i added fluid. It may have7 gotten air in the lines and it bleed it out and needs filled again.
