I walked out to my boat yesterday and the bilge was running and the master power was off. I could not get the bilge to turn off so I unhooked the negative side of the battery and hooked it back up in about 5 minutes. That cut the bilge pump off but now nothing on the touch pad works(horn, bilge, aerorator, lights). I checked the breakers that run off the battery cables and none of them are tripped. Could it have blown a fuse when I hooked the battery cable back up?? It did throw a little spark when I touched the cable to the battery post… If this may be the case where are the fuses, I could not find them. Any suggestions???
