Quote: (Also i couldnt get fluid to flow thru the system until i hooked the plug up to my truck and put it into reverse im guessing the back up solenoid is closed and when power is applied it opens up.)That is the weird part of your description, as the solenoid should let fluid pass until power is applied and then close off. I am thinking that the solenoid may be bad also, and when you applied power it is trying to close but there is trash or rust in it that has it partially blocked and when you applied power the plunger tried to close but hit whatever is in the way, it moved a tiny bit and and started letting some fluid pass, but it plugs the system back off when you remove power.
