Thanks for the info. The brakes are disc brakes, replaced in ~ 2000 by the original owner. RatherBfishing, thanks for the info on the coupler. Ill check online for a manual. After that Ill start by bleeding the brakes and go from there. If all the upfront stuff is good I should be able to take care of the brake job. BCB, is the master cylinder something I can get from you guys, or would I contact Attwood?
