Get at least one of the seals for replacement first in the event you need it. Remove the wheels, slowly tap the cap side to side for removal. If the grease looks good, then add some if needed and just replace the cap. Score the back of the aluminum cap head for replacement and tap back in with a wooden block and moderate size hammer. Do you have an increase in temperatures? If not then we doubt you have an issue. BCB
