Here are the pics I promisedI used 3/8 thick polymer plastic cutting boards rom Walmart .drilled the holes accordingly, and wallowed out the holes so I have a little wiggle room since the trays are not exactly square. Not sure which way I will mount the charger , either sideways or cords going through the back near pedestal pole, and mou t the prop as you see it, just gonna double up the thickness here with scrap from cutting, and glue in place getting long Bo,t , nuts and fender washers for the prop. Hope this helps your decision. Last edited by scubaman154 on March 30th, 2013, 11:38 pm, edited 3 times in total.
