Home › Forums › Bass Cat Boats › Trying to upgrade trailer to tandem axle.
I have a 1991 Pantera II with a single axle trailer. I would like to upgrade to a tandem axle trailer. I found a Bass Cat trailer for a 2003 Cougar. I realize Bass Cat makes trailers that fit each individual boat. With that said, the boards on both trailers seem to be very similar. Im trying to figure out exactly what Ill need to do in order to make the Cougar trailer work. Both trailers are 20 ft. long. Will it work the way it is or will I have to make modifications? Any help will be greatly appreciated!
It can be done though the trailer is longer, wider and the bunk settings are totally different. Mismatched is our thoughts.
Thanks for the quick reply. You say it can be done. What would need to be done to the trailer, in order to use it?
That is more than you would believe. It will be a consuming process as the bunks are very different.
Check out Boat Trader.com. Select Bass Cat as manufacturer and sort by low to high. There is a dual axle trailer for an older Pantera on there. Should be one of the first entries. Looks like it probably needs some work but probably easier than refitting a trailer from a different hull. The outfit that is selling it is in the Atlanta area. Also, they have been trying to sell it for a few years so I would guess that price is very negotiable. Hope this is helpful. Good luck.
Single axle pulls easier and rides better, why change a good thing ? Are you really getting that far from the house ?
Thanks for the replies. My son is participating in youth tournaments out of state. We basically travel 4-6 hours (one way) every 3rd or 4th weekend of each month. Ive already had a blowout and as a result, I find our trips taking longer then they should. Not to mention, I am a lot more stressed traveling to distant lakes. I was thinking a tandem axle trailer would allow our trips to be less stressful. Since this is the first boat Ive owned, Im open to suggestions and comments. My son loves bass fishing and I want to do whatever I can to allow him to participate in tournaments. Unfortunately, I cant find youth tournaments in our state (or at least close to home), so were forced to travel out of state.
socrne1 – you sound like an awesome dad! The tandem trailers give you more tires in case of a blowout, but you wouldnt really want to tow a tandem any serious distance with a flat, anyway, which would mean youd still have to change the tire. If you dont have Goodyear Marathons on the trailer, thats really a good place to start with your existing trailer. Much less chance of a blowout with tires that are made for trailering — especially when youve got long hauls. The premium tires on the Panteras and Jaguars used to be Firestone Firehawks, and in my experience, while they looked pretty, they werent great tires for long hauling or trailering on bad roads. Dad was in a boat accident at a tournament one year, and I had to fly from NYC to Minnesota to get him out of the hospital and on a plane to Florida, then I towed the boat back from Red Wing, MN to Palm Bay, FL. One Firehawk blew out about halfway home, and the other had a bulge in the sidewall just as I made it to Dads driveway. We were always replacing those Firehawks. So, good tires for your existing trailer (if you dont already have Marathons) might be a better investment in the longrun, because youve still got to change those flats on a tandem when youre away from home.
Agree w/bright work 100%. More tires may not mean less chances for problems. If you have a blowout or flat on tandem trailer, you cant just keep on going. You still have to stop and change the tire. Not doing this risks damaging those beautiful fiberglass fenders on your trailer. The steel belt on a shredded tire will even damage a steel fender. Been there done that. Bottom line you have to change flats ASAP ( like stop right now ) single or double axle. Since your boat is a 1991, how old was the tire that blew? Some guys are changing their tires every 4 -5 years, even if the tread is good. There was a recent thread about trailer tires that covers much of these problems with tires. Use the search function to find it. Lots of good advice there. Since this is your first boat, one thing you have to do is keep the boat in your scan as you drive. I probably watch my boat and trailer as much as I do the road in front of me. You cant forget about it. Thats just part of trailering. With experience it becomes comfortable. Follow BWs excellent advice. Good luck with the Bass Cat…..And catch a bunch of fish!
Make sure your trailer rides as level as possible!
