Hmm, so now Im a little confused. Coming out of the wiring harnes in the bilge area at the pump location is a brown and a black wire. In assuming these connect straight to the pump. At the float switch coming out of the harnes is a brown wire with white stripe and a black wire. How should the float switch be connected to these two wires? Not sure at this point if my float is bad or not. When I raise it, I was expecting continuity but I dont get it when I connect my meter to both wires from the float. Thanks,Wannabe…Last edited by Wannabe on January 27th, 2012, 1:19 am, edited 1 time in total.
