I have a 2005 Sabre with an XR6. It seems to get better water pressure with a Fury and no plugs, than a medium sized plugs in a Tempest. Problem is it seems to be reading too high now. Im used to around 13-14 psi at WOT but its ready almost 20. When I take off its over 25 and thats not right. Anyone had this happen before ? Should I disconnect the line at both ends and blow air through it ? I never get sprayed under the dash with water so I dont want to mess anything up with the connection if possible. Thanks.2005 Sabre, 150 XR6, Minn Kota Fortrex with Lowrance electronics
