I need some help on figuring out a newly developed problem….I have a 2010 Puma/250 SHO. When cranking the SHO, my 998 on the bow turns off and sometimes the 998 on the dash turns off. Im sure it is from low voltage as the motor is cranked, I had 850 cranking amp battery, and replaced it with a 1000 cranking amp battery, with the same results. I checked the voltage on the hummingbirds at their plugs with 2 different volt meters and both were 12.6 volts, but when I put the plug back into the units and turn them on they both show 11.1 volts. Any suggestions?
