First off, I have a 13 Eyra. My trim switches on the front are not working. So I went in to take a look and see if I could figure it out myself. When I took the Nav/Acc/trim panel off it was a cluster. I tried wiggling some wires to see if there was a short but I didnt find anything. Whoever owned the boat before me had wired things into the panel and clipped the wires before selling it to take the electronics off. Which wire is the hot wire in the panel? I found a black wire just hanging out. There is a white wire too. I need a diagram if anyone has one so I can start over. Thanks. Jesse
Generally, blue (or blue/white) for up, green (or green/white) for down, and red (or red/white) for power. If the previous owner rewired the front, you may have to trace back and find them.
Look down in the foot recess and there is a switch beside the foot pedal. Turn that one on and it is a master for the bow switches. We had some complaints from fat footed folks, and amazingly we get much more of this than previous complaints. If its not that, then its a wire knocked off and removing the panel is next.
